[Qgis-developer] GRASS7 build error
Radim Blazek
radim.blazek at gmail.com
Sat Oct 17 04:00:28 PDT 2015
If you have GRASS 7 installed and you want to compile GRASS 7
provider/plugin, use WITH_GRASS7=ON, otherwise OFF.
If GRASS 7 is not found automatically, specify also GRASS_PREFIX7 and
GRASS_INCLUDE_DIR7.
Radim
On Sat, Oct 17, 2015 at 9:58 AM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> Hi Radim,
> On Wed, Oct 14, 2015 at 11:08 PM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
>> Hi all, (Radim)
>> I am getting the following error on building: http://codepad.org/ZZiB2R63
>> Is this related to a local problem?
>> Anyone confirms?
> I don't know if this mail was notified to you, but I am noticing a
> strange issue compiling qgis with grass support.
> If I use only -DWITH_GRASS7=ON I get a build error (as from codepad
> link in the previous mail) while adding -DWITH_GRASS=ON
> I can build just fine.
> is this the expected behaviour?
> is it necessary to have both grass versions?
> Thanks,
> -SL
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
