[Qgis-developer] GRASS7 build error
Radim Blazek radim.blazek at gmail.com
Sun Oct 18 05:40:07 PDT 2015
In fact, quite stupid bug, fixed.
Radim
On Sun, Oct 18, 2015 at 1:09 PM, Pedro VenĂ¢ncio
<pedrongvenancio at gmail.com> wrote:
> Hi,
> I also confirm this behavior. If I have GRASS_PREFIX and GRASS6 and GRASS7
> both on, the compilation goes well.
> If I put just GRASS7 on, I get:
> [ 62%] Building CXX object
> src/gui/CMakeFiles/qgis_gui.dir/layertree/moc_qgslayertreeview.cxx.o
> src/gui/CMakeFiles/qgis_gui.dir/layertree/moc_qgslayertreeviewdefaultactions.cxx.o
> src/gui/CMakeFiles/qgis_gui.dir/editorwidgets/moc_qgswebviewconfigdlg.cxx.o
> src/gui/CMakeFiles/qgis_gui.dir/editorwidgets/moc_qgswebviewwidgetwrapper.cxx.o
> Linking CXX shared library ../../output/lib/libqgis_gui.so
> [ 62%] Built target qgis_gui
> make: ** [all] Erro 2
> But if I put only GRASS6 on, it also compiles well.
> So, it seems that there is something with the GRASS7, which also requires
> GRASS6.
> Pedro
> 2015-10-17 12:30 GMT+01:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
>> On 17-10-15 13:00, Radim Blazek wrote:
>>> If you have GRASS 7 installed and you want to compile GRASS 7
>>> provider/plugin, use WITH_GRASS7=ON, otherwise OFF.
>>> If GRASS 7 is not found automatically, specify also  GRASS_PREFIX7 and
>>>   GRASS_INCLUDE_DIR7.
>> Hi Radim, thanks for the feedback. I have installed (compiled from source)
>> GRASS7. I used the option WITH_GRASS7=ON (I also always specify
>> GRASS_PREFIX7 and GRASS_INCLUDE_DIR7). But that results in the compilation
>> to fail. If however I use WITH_GRASS=ON and WITH_GRASS7, I can build QGIS
>> with the GRASS7 plugin. I thought it strange one also need to set
>> WITH_GRASS=ON, and from your reaction I get that it shouldn't be required? I
>> had seen a similar message on the email list, but can't find it right now.
>> But it means I am (probably) not the only one experiencing this.
>>> Radim
>>> On Sat, Oct 17, 2015 at 9:58 AM, Salvatore Larosa <lrssvtml at gmail.com>
>>> wrote:
>>>> Hi Radim,
>>>> On Wed, Oct 14, 2015 at 11:08 PM, Salvatore Larosa <lrssvtml at gmail.com>
>>>> wrote:
>>>>> Hi all,  (Radim)
>>>>> I am getting the following error on building:
>>>>> http://codepad.org/ZZiB2R63
>>>>> Is this related to a local problem?
>>>>> Anyone confirms?
>>>> I don't know if this mail was notified to you, but I am noticing a
>>>> strange issue compiling qgis with grass support.
>>>> If I use only -DWITH_GRASS7=ON I get a build error (as from codepad
>>>> link in the previous mail) while adding -DWITH_GRASS=ON
>>>> I can build just fine.
>>>> is this the expected behaviour?
>>>> is it necessary to have both grass versions?
>>>> Thanks,
>>>> -SL
>>>> Salvatore Larosa
>>>> linkedIn: http://linkedin.com/in/larosasalvatore
>>>> twitter: @lrssvt
>>>> skype: s.larosa
>>>> IRC: lrssvt on freenode
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
