[Qgis-developer] GRASS7 build error
Pedro VenĂ¢ncio
pedrongvenancio at gmail.com
Sun Oct 18 04:09:22 PDT 2015
I also confirm this behavior. If I have GRASS_PREFIX and GRASS6 and GRASS7
both on, the compilation goes well.
If I put just GRASS7 on, I get:
[ 62%] Building CXX object
src/gui/CMakeFiles/qgis_gui.dir/layertree/moc_qgslayertreeview.cxx.o
src/gui/CMakeFiles/qgis_gui.dir/layertree/moc_qgslayertreeviewdefaultactions.cxx.o
src/gui/CMakeFiles/qgis_gui.dir/editorwidgets/moc_qgswebviewconfigdlg.cxx.o
src/gui/CMakeFiles/qgis_gui.dir/editorwidgets/moc_qgswebviewwidgetwrapper.cxx.o
Linking CXX shared library ../../output/lib/libqgis_gui.so
[ 62%] Built target qgis_gui
make: ** [all] Erro 2
But if I put only GRASS6 on, it also compiles well.
So, it seems that there is something with the GRASS7, which also requires
GRASS6.
Pedro
2015-10-17 12:30 GMT+01:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
> On 17-10-15 13:00, Radim Blazek wrote:
>> If you have GRASS 7 installed and you want to compile GRASS 7
>> provider/plugin, use WITH_GRASS7=ON, otherwise OFF.
>> If GRASS 7 is not found automatically, specify also GRASS_PREFIX7 and
>> GRASS_INCLUDE_DIR7.
> Hi Radim, thanks for the feedback. I have installed (compiled from source)
> GRASS7. I used the option WITH_GRASS7=ON (I also always specify
> GRASS_PREFIX7 and GRASS_INCLUDE_DIR7). But that results in the compilation
> to fail. If however I use WITH_GRASS=ON and WITH_GRASS7, I can build QGIS
> with the GRASS7 plugin. I thought it strange one also need to set
> WITH_GRASS=ON, and from your reaction I get that it shouldn't be required?
> I had seen a similar message on the email list, but can't find it right
> now. But it means I am (probably) not the only one experiencing this.
>> Radim
>> On Sat, Oct 17, 2015 at 9:58 AM, Salvatore Larosa <lrssvtml at gmail.com>
>> wrote:
>>> Hi Radim,
>>> On Wed, Oct 14, 2015 at 11:08 PM, Salvatore Larosa <lrssvtml at gmail.com>
>>> wrote:
>>>> Hi all, (Radim)
>>>> I am getting the following error on building:
>>>> http://codepad.org/ZZiB2R63
>>>> Is this related to a local problem?
>>>> Anyone confirms?
>>> I don't know if this mail was notified to you, but I am noticing a
>>> strange issue compiling qgis with grass support.
>>> If I use only -DWITH_GRASS7=ON I get a build error (as from codepad
>>> link in the previous mail) while adding -DWITH_GRASS=ON
>>> I can build just fine.
>>> is this the expected behaviour?
>>> is it necessary to have both grass versions?
>>> Thanks,
>>> -SL
>>> Salvatore Larosa
>>> linkedIn: http://linkedin.com/in/larosasalvatore
>>> twitter: @lrssvt
>>> skype: s.larosa
>>> IRC: lrssvt on freenode
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151018/53579d97/attachment.html>
