[Qgis-developer] GRASS7 build error
Paulo van Breugel
p.vanbreugel at gmail.com
Sun Oct 18 07:27:54 PDT 2015
On Sun, Oct 18, 2015 at 2:40 PM, Radim Blazek <radim.blazek at gmail.com>
wrote:
> In fact, quite stupid bug, fixed.
Great, thanks for the quick fix
> Radim
> On Sun, Oct 18, 2015 at 1:09 PM, Pedro VenĂ¢ncio
> <pedrongvenancio at gmail.com> wrote:
> > Hi,
> > I also confirm this behavior. If I have GRASS_PREFIX and GRASS6 and
> GRASS7
> > both on, the compilation goes well.
> > If I put just GRASS7 on, I get:
> > [ 62%] Building CXX object
> > src/gui/CMakeFiles/qgis_gui.dir/layertree/moc_qgslayertreeview.cxx.o
> src/gui/CMakeFiles/qgis_gui.dir/layertree/moc_qgslayertreeviewdefaultactions.cxx.o
> src/gui/CMakeFiles/qgis_gui.dir/editorwidgets/moc_qgswebviewconfigdlg.cxx.o
> src/gui/CMakeFiles/qgis_gui.dir/editorwidgets/moc_qgswebviewwidgetwrapper.cxx.o
> > Linking CXX shared library ../../output/lib/libqgis_gui.so
> > [ 62%] Built target qgis_gui
> > make: ** [all] Erro 2
> > But if I put only GRASS6 on, it also compiles well.
> > So, it seems that there is something with the GRASS7, which also requires
> > GRASS6.
> > Pedro
> > 2015-10-17 12:30 GMT+01:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
> >> On 17-10-15 13:00, Radim Blazek wrote:
> >>> If you have GRASS 7 installed and you want to compile GRASS 7
> >>> provider/plugin, use WITH_GRASS7=ON, otherwise OFF.
> >>> If GRASS 7 is not found automatically, specify also GRASS_PREFIX7 and
> >>> GRASS_INCLUDE_DIR7.
> >> Hi Radim, thanks for the feedback. I have installed (compiled from
> source)
> >> GRASS7. I used the option WITH_GRASS7=ON (I also always specify
> >> GRASS_PREFIX7 and GRASS_INCLUDE_DIR7). But that results in the
> compilation
> >> to fail. If however I use WITH_GRASS=ON and WITH_GRASS7, I can build
> QGIS
> >> with the GRASS7 plugin. I thought it strange one also need to set
> >> WITH_GRASS=ON, and from your reaction I get that it shouldn't be
> required? I
> >> had seen a similar message on the email list, but can't find it right
> now.
> >> But it means I am (probably) not the only one experiencing this.
> >>> Radim
> >>> On Sat, Oct 17, 2015 at 9:58 AM, Salvatore Larosa <lrssvtml at gmail.com>
> >>> wrote:
> >>>> Hi Radim,
> >>>> On Wed, Oct 14, 2015 at 11:08 PM, Salvatore Larosa <
> >>>> wrote:
> >>>>> Hi all, (Radim)
> >>>>> I am getting the following error on building:
> >>>>> http://codepad.org/ZZiB2R63
> >>>>> Is this related to a local problem?
> >>>>> Anyone confirms?
> >>>> I don't know if this mail was notified to you, but I am noticing a
> >>>> strange issue compiling qgis with grass support.
> >>>> If I use only -DWITH_GRASS7=ON I get a build error (as from codepad
> >>>> link in the previous mail) while adding -DWITH_GRASS=ON
> >>>> I can build just fine.
> >>>> is this the expected behaviour?
> >>>> is it necessary to have both grass versions?
> >>>> Thanks,
> >>>> -SL
> >>>> Salvatore Larosa
> >>>> linkedIn: http://linkedin.com/in/larosasalvatore
> >>>> twitter: @lrssvt
> >>>> skype: s.larosa
> >>>> IRC: lrssvt on freenode
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151018/72accbd2/attachment.html>
