[Qgis-developer] GRASS layer history?
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Mon Oct 19 02:56:11 PDT 2015
Hi Paolo,
I guess you are referring to the "command history" of your GRASS session?
It is stored in a file named ".bash_history" which is a simple text file, located within the folder of your mapset (GRASSDB/LOCATION/MAPSET/.bash_history).
You should be able to access it via browser...
Otherwise r.info and v.info should be able to show the history of a raster or vector map.
Hope that helps...
Cheers
Stefan
-----Original Message-----
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Paolo Cavallini
Sent: 19. oktober 2015 11:38
To: qgis-developer <qgis-developer at lists.osgeo.org>
Subject: [Qgis-developer] GRASS layer history?
Hi all,
I cannot find, in the current plugin, a way of recovering the history of either rasters or vectors: is this a known limitation, or am I missing how to get it?
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
