[Qgis-developer] GRASS layer history?
    Paolo Cavallini
    cavallini at faunalia.it
    Mon Oct 19 02:59:13 PDT 2015
Il 19/10/2015 11:56, Blumentrath, Stefan ha scritto:
> I guess you are referring to the "command history" of your GRASS session?
> It is stored in a file named ".bash_history" which is a simple text file, located within the folder of your mapset (GRASSDB/LOCATION/MAPSET/.bash_history).
> You should be able to access it via browser...
> Otherwise r.info and v.info should be able to show the history of a raster or vector map.
That is what I was looking for. In previous version, the layer history
was available from the layer metadata. I found this more convenient.
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
