[Qgis-developer] Improving ftools geoprocessing tools
Victor Olaya
volayaf at gmail.com
Thu Oct 22 06:59:27 PDT 2015
>> Yep. I think the user-friendliness of ftools are that a/ algorithms
>> are offered in a simple and accessible menu items, and b/ the menu
>> item icons _greatly_ ease the understanding of what algorithms do.
Icon support is already in Processing. The first versions actually
used the same ftools icons, but I removed that because there were new
algorithms being added, and it was quite messy to see some algorithms
with icons and others with the default icon. Instead, I started using
the same icon for all algorithms for a given provider, for the sake of
homogeneity.
However, the mechanism that I implemented for putting processing
algorithms in a menu allows to set an icon, so the current ftools menu
can be perfectly replicated, including icons
I copy here an example that I added in another thread, about how to
replicate the Raster/Conversion menu from Processing
import os
from GdalTools import GdalTools
from processing.gui.utils import addAlgorithmEntry
from PyQt4.QtGui import *
def addRasterAlgorithm(name, group, iconName):
icon = QIcon(os.path.join(os.path.dirname(GdalTools.__file__),
"icons", iconName + ".png"))
addAlgorithmEntry(name, "Raster", group, icon = icon)
addRasterAlgorithm("gdalogr:rasterize", "Conversion", "rasterize")
addRasterAlgorithm("gdalogr:translate", "Conversion", "translate")
addRasterAlgorithm("gdalogr:pcttorgb", "Conversion", "24-to-8-bits")
addRasterAlgorithm("gdalogr:rgbtopct", "Conversion", "8-to-24-bits")
addRasterAlgorithm("gdalogr:polygonize", "Conversion", "polygonize")
The addAlgorithmEntry is a part of Processing since quite a few
commits ago, and it allows to put an algorithm "outside" of the
toolbox, in a menu entry.
So the code is basically there, it is just a matter of finding out
which algorithms are missing and deciding where to call this methods
from. Then I guess we could use that funding to improve algorithms and
make them more robust and fast
Cheers
>> Both can be added to processing.
>> On 22 Oct 2015 20:26, "Matthias Kuhn" <matthias at opengis.ch
>> <mailto:matthias at opengis.ch>> wrote:
>> Hi Giovanni,
>> On 10/22/2015 02:38 PM, Giovanni Manghi wrote:
>> > This users are
>> > usually not able to handle (or willingly to) the possible
>> problems of
>> > using a toolbox based on other software.
>> There are a number of internal algorithms available in processing
>> (i.e.
>> no external dependencies).
>> Unfortunately they are duplicates of ftools algorithms. But they have
>> the advantage that they can be used in models.
>> So if something is going to be improved it should be those - or we end
>> up with a situation where we have fast algorithms in the menus but the
>> same algorithm slower in the toolbox.
>> Therefore the plan of action should be:
>> * Create menu entries for often used (internal) processing algorithms
>> * Remove ftools algorithms
>> * Identify slow algorithms
>> * Improve performance
>> This will solve João's problems in the most sustainable and effective
>> way possible.
>> Chers
>> Matthias
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
