[Qgis-developer] New GRASS plugin: a test drive
Pedro VenĂ¢ncio
pedrongvenancio at gmail.com
Thu Oct 22 16:39:03 PDT 2015
>> It
> >> is compiled with LFS, which adds -D_LARGEFILE_SOURCE
> >> -D_FILE_OFFSET_BITS=64 compiler flags. Try to add -D_LARGEFILE_SOURCE
> >> -D_FILE_OFFSET_BITS=64 to QGIS cmake CXX_EXTRA_FLAGS
> > With this flags it also works without problems!
> I added check for _FILE_OFFSET_BITS in Make/Platform.h, now it should
> compile correctly without manually setting CXX_EXTRA_FLAGS. Configure
> should print:
> -- Found GRASS 7: /usr/lib/grass70/ (7.0.2RC1, off_t size = 8)
It works Radim! Thanks!!
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151023/a7768b62/attachment.html>
