[Qgis-developer] [Linux Mint] QGIS Master 3d93237
Matthias Kuhn
matthias at opengis.ch
Mon Oct 26 09:53:55 PDT 2015
Hi Luigi,
What's the python version on your system?
Matthias
On 10/26/2015 10:32 AM, Luigi Pirelli wrote:
> Hi Mathias
> seems related with this your commit about Python3 compatbility
> cd0eb05deddc610a1a79c40163504efddfe3da3a
> src/python/qgspythonutilsimpl.cpp
> - if ( !PyString_Check( obResult ) )
> + if ( !PyUnicode_Check( obResult ) )
> TRACEBACK_FETCH_ERROR( "getvalue() did not return a string" );
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Elance: https://www.elance.com/s/edit/luigipirelli/
> * GitHub: https://github.com/luipir
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis
> On 25 October 2015 at 22:06, Luigi Pirelli <luipir at gmail.com> wrote:
>> confirmed also ubuntu 15.10 and just pulled the qgis code.
>> last log messages was oading the python module:
>> src/app/qgisapp.cpp: 7911: (loadPythonSupport) [3ms] load library
>> /home/ginetto/PROGRAMMING/QGIS-2.0-master/build/output/lib/qgispython
>> (2.13.0)
>> regards
>> Luigi Pirelli
>> * Mastering QGIS:
>> On 25 October 2015 at 15:42, João Gaspar <joao.f.r.gaspar at gmail.com> wrote:
>>> Hi guys,
>>> today after compile and install the master version when i open QGIS Master
>>> and he give me this error:
>>> Couldn't load PyQGIS.
>>> Python support will be disabled.
>>> Python version:
>>> 2.7.6 (default, Jun 22 2015, 18:01:27)
>>> [GCC 4.8.2]
>>> QGIS version:
>>> 2.13.0-Master 'Master', 3d93237
>>> Python path:
>>> ['/home/joao/apps/share/qgis/python', u'/home/joao/.qgis2/python',
>>> u'/home/joao/.qgis2/python/plugins',
>>> '/home/joao/apps/share/qgis/python/plugins', '/usr/lib/python2.7',
>>> '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk',
>>> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
>>> '/usr/local/lib/python2.7/dist-packages',
>>> '/usr/lib/python2.7/dist-packages',
>>> '/usr/lib/python2.7/dist-packages/PILcompat',
>>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>>> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
>>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
>>> What can be the problem?
>>> Regards
>>> João
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151026/1a31fa49/attachment.sig>
