[Qgis-developer] [Linux Mint] QGIS Master 3d93237
Luigi Pirelli luipir at gmail.com
Mon Oct 26 10:57:46 PDT 2015
Python 2.7.10 (default, Oct 14 2015, 16:09:02)
[GCC 5.2.1 20151010] on linux2
and
Python 3.4.3+ (default, Oct 14 2015, 16:03:50)
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Elance: https://www.elance.com/s/edit/luigipirelli/
* GitHub: https://github.com/luipir
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 26 October 2015 at 17:53, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Luigi,
> What's the python version on your system?
> Matthias
> On 10/26/2015 10:32 AM, Luigi Pirelli wrote:
>> Hi Mathias
>> seems related with this your commit about Python3 compatbility
>> cd0eb05deddc610a1a79c40163504efddfe3da3a
>> src/python/qgspythonutilsimpl.cpp
>> -  if ( !PyString_Check( obResult ) )
>> +  if ( !PyUnicode_Check( obResult ) )
>>      TRACEBACK_FETCH_ERROR( "getvalue() did not return a string" );
>> Luigi Pirelli
>> * Mastering QGIS:
>> On 25 October 2015 at 22:06, Luigi Pirelli <luipir at gmail.com> wrote:
>>> confirmed also ubuntu 15.10 and just pulled the qgis code.
>>> last log messages was oading the python module:
>>> src/app/qgisapp.cpp: 7911: (loadPythonSupport) [3ms] load library
>>> /home/ginetto/PROGRAMMING/QGIS-2.0-master/build/output/lib/qgispython
>>> (2.13.0)
>>> regards
>>> Luigi Pirelli
>>> * Mastering QGIS:
>>> On 25 October 2015 at 15:42, João Gaspar <joao.f.r.gaspar at gmail.com> wrote:
>>>> Hi guys,
>>>> today after compile and install the master version when i open QGIS Master
>>>> and he give me this error:
>>>> Couldn't load PyQGIS.
>>>> Python support will be disabled.
>>>> Python version:
>>>> 2.7.6 (default, Jun 22 2015, 18:01:27)
>>>> [GCC 4.8.2]
>>>> QGIS version:
>>>> 2.13.0-Master 'Master', 3d93237
>>>> Python path:
>>>> ['/home/joao/apps/share/qgis/python', u'/home/joao/.qgis2/python',
>>>> u'/home/joao/.qgis2/python/plugins',
>>>> '/home/joao/apps/share/qgis/python/plugins', '/usr/lib/python2.7',
>>>> '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk',
>>>> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
>>>> '/usr/local/lib/python2.7/dist-packages',
>>>> '/usr/lib/python2.7/dist-packages',
>>>> '/usr/lib/python2.7/dist-packages/PILcompat',
>>>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>>>> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
>>>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
>>>> What can be the problem?
>>>> Regards
>>>> João
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
