[Qgis-developer] [Linux Mint] QGIS Master 3d93237
Matthias Kuhn matthias at opengis.ch
Mon Oct 26 15:10:42 PDT 2015
Do you have any evidence that it's the PyUnicode_Check? I think that
should be supported by Python 2.7 as well.
The other error by Richard from IRC  (PyUnicode_AsUTF8) makes more
sense, since it's not supported by 2.7 but it should be ifdef'd, strange
that this happens. Maybe re-running cmake would help??
On 10/26/2015 06:57 PM, Luigi Pirelli wrote:
> Python 2.7.10 (default, Oct 14 2015, 16:09:02)
> [GCC 5.2.1 20151010] on linux2
> and
> Python 3.4.3+ (default, Oct 14 2015, 16:03:50)
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Elance: https://www.elance.com/s/edit/luigipirelli/
> * GitHub: https://github.com/luipir
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis
> On 26 October 2015 at 17:53, Matthias Kuhn <matthias at opengis.ch> wrote:
>> Hi Luigi,
>> What's the python version on your system?
>> Matthias
>> On 10/26/2015 10:32 AM, Luigi Pirelli wrote:
>>> Hi Mathias
>>> seems related with this your commit about Python3 compatbility
>>> cd0eb05deddc610a1a79c40163504efddfe3da3a
>>> src/python/qgspythonutilsimpl.cpp
>>> -  if ( !PyString_Check( obResult ) )
>>> +  if ( !PyUnicode_Check( obResult ) )
>>>      TRACEBACK_FETCH_ERROR( "getvalue() did not return a string" );
>>> Luigi Pirelli
>>> * Mastering QGIS:
>>> On 25 October 2015 at 22:06, Luigi Pirelli <luipir at gmail.com> wrote:
>>>> confirmed also ubuntu 15.10 and just pulled the qgis code.
>>>> last log messages was oading the python module:
>>>> src/app/qgisapp.cpp: 7911: (loadPythonSupport) [3ms] load library
>>>> /home/ginetto/PROGRAMMING/QGIS-2.0-master/build/output/lib/qgispython
>>>> (2.13.0)
>>>> regards
>>>> Luigi Pirelli
>>>> * Mastering QGIS:
>>>> On 25 October 2015 at 15:42, João Gaspar <joao.f.r.gaspar at gmail.com> wrote:
>>>>> Hi guys,
>>>>> today after compile and install the master version when i open QGIS Master
>>>>> and he give me this error:
>>>>> Couldn't load PyQGIS.
>>>>> Python support will be disabled.
>>>>> Python version:
>>>>> 2.7.6 (default, Jun 22 2015, 18:01:27)
>>>>> [GCC 4.8.2]
>>>>> QGIS version:
>>>>> 2.13.0-Master 'Master', 3d93237
>>>>> Python path:
>>>>> ['/home/joao/apps/share/qgis/python', u'/home/joao/.qgis2/python',
>>>>> u'/home/joao/.qgis2/python/plugins',
>>>>> '/home/joao/apps/share/qgis/python/plugins', '/usr/lib/python2.7',
>>>>> '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk',
>>>>> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
>>>>> '/usr/local/lib/python2.7/dist-packages',
>>>>> '/usr/lib/python2.7/dist-packages',
>>>>> '/usr/lib/python2.7/dist-packages/PILcompat',
>>>>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>>>>> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
>>>>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
>>>>> What can be the problem?
>>>>> Regards
>>>>> João
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151026/1d9849d5/attachment.sig>
