[Qgis-developer] no grass plugin in qgis installed from osgeo4w
Veronica Andreo veroandreo at gmail.com
Tue Oct 27 12:55:19 PDT 2015
Hi there :)
2015-10-27 16:30 GMT-03:00 Pedro VenĂ¢ncio <pedrongvenancio at gmail.com>:
> Hi,
>> I've installed grass and qgis (2.12) from the osgeo4w installer 32 bits (
>> https://trac.osgeo.org/osgeo4w/), using "Advance install". To get grass
>> plugin, I also selected from Libs:
>> qgis-grass plugin (for grass64)
>> qgis-grass plugin common
>> qgis-grass plugin7 (for grass7)
>> Both, testing with grass7.0.2RC1-1 and grass7.0.1-1, I do not find grass
>> plugin in Plugin --> Manage and Install Plugins. Using QGIS with grass64
>> works fine and plugin is there, though.
> I confirm this.
> I've installed
> qgis-rel-dev 2.12.0-3
> qgis-dev 2.13.0-3
> and I get GRASS 7 plugin working properly, using grass 7.0.1-1 and running
> qgis-rel-dev-g7.0.1.bat and qgis-dev-g7.0.1.bat, respectively.
> I also installed qgis 2.12.0-1 (qgis: QGIS Desktop), and running
> qgis-grass7.bat, I don't have the GRASS 7 plugin.
> Moreover, if I try to uninstall grass I get:
> grass (7.0.2RC1-1)
> GRASS GIS - stable release
> Required by: qgis-dev, qgis-grass-plugin7, qgis-rel-dev
> So, it seems that it is not a dependency for 2.12.0-1, which leads to
> suspect that this version was not compiled with grass 7. Am I wrong?
> Veronica, please install qgis-rel-dev 2.12.0-3 instead of qgis 2.12.0-1.
> I did. And I got it working!! So, grass7 plugin is not in qgis 2.12.0-1,
but it is there in qgis-rel-dev 2.12.0-3
Thank you so much for your help, Padro! And all!
Vero
ps: i'm also copying grass-dev for record
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151027/afb84a78/attachment.html>
