[Qgis-developer] use ogr2ogr in a plugin
Even Rouault
even.rouault at spatialys.com
Thu Oct 29 02:06:45 PDT 2015
Le jeudi 29 octobre 2015 09:59:50, Denis Rouzaud a écrit :
> Cool feature, thanks for the info.
> What's the time frame for 2.1?
~ April / May 2016
> On 10/29/2015 09:55 AM, Even Rouault wrote:
> > Le jeudi 29 octobre 2015 09:38:38, Victor Olaya a écrit :
> >> 2015-10-29 9:18 GMT+01:00 Matthias Kuhn <matthias at opengis.ch>:
> >>> Hi Denis,
> >>> I assume the path env variable should be appropriately set in all OS'es
> >>> when inside QGIS so calling ogr2ogr (e.g. subprocess.call( 'ogr2ogr
> >>> params' ) should just work. But to be honest, I never tried.
> >>> Matthias
> >> That's actually what the ogr2ogr algorithm in Processing does...
> >> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/
> >> gda l/ogr2ogr.py
> > Just taking advantage of this thread to advertize RFC 59.1 : GDAL/OGR
> > utilities as a library that will be part of GDAL 2.1 :
> > https://trac.osgeo.org/gdal/wiki/rfc59.1_utilities_as_a_library
> > And the current hardcoded list of formats and extensions could be
> > dynamically populated from the metadata of drivers starting with GDAL
> > 2.0 :
> > from osgeo import gdal
> > for i in range(gdal.GetDriverCount()):
> > drv = gdal.GetDriver(i)
> > if drv.GetMetadataItem(gdal.DCAP_VECTOR) and \
> > drv.GetMetadataItem(gdal.DCAP_CREATE):
> > extensions = drv.GetMetadataItem(gdal.DMD_EXTENSIONS)
> > if extensions is not None:
> > print('%s: %s' % (drv.GetDescription(), extensions))
> > Even
http://www.spatialys.com
