[Qgis-developer] use ogr2ogr in a plugin
Luigi Pirelli
luipir at gmail.com
Thu Oct 29 07:54:45 PDT 2015
may you use processing wrapper to ogr2gr?
e.g.
import processing
processing.runalg("your processing command get with
processing.alglist",... etc etc)
is that you are looking for?
in this waqy you are os independent.
regards,
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Elance: https://www.elance.com/s/edit/luigipirelli/
* GitHub: https://github.com/luipir
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 28 October 2015 at 15:09, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi all,
> I would like to use ogr2ogr in a plugin, and I wonder if it's possible
> to call the one that has been installed along QGIS, independently from
> the OS.
> The idea is to connect to a Postgres DB and writes content of tables
> into shapefiles. One way would be to load the tables in QGIS and write
> content manually, but a single ogr2ogr would be quite straightforward.
> Thanks a lot for any lead,
> Denis
> Qgis-developer mailing list
