[Qgis-developer] Compile QGis Problem.
Ko Nagase nagase at georepublic.co.jp
Sun Sep 6 19:52:13 PDT 2015
Hi Jacory,
Thanks for your reply.
2015-09-07 11:36 GMT+09:00 Jacory <jacorygao at outlook.com>:
> Thanks a lot, I solved the problem under your suggestion.
> I did it in another way, I changed the path variable of Qt “qmake.exe” in
> CMake. When I followed your suggestion, I opened CMake and found the
> “qmake.exe" path variable is assigned to "osgeo4w\bin” directory, but the
> version exactly I use is in another path. So I changed the path, and
> regenerated the “sln” in CMake. Now the problem has gone.
> Thank you very much, I think I can never find the solution on my own.
Okay, no problem.
> And would you mind to tell me the IDE you use on Mac? I have a Macbook Air
> 2014 with 8G memory, but I’m not familiar to use it for developing, I use
> windows normally. I’m just curious, and I really want to use my Mac, it’s
> really beautiful.
I tried QGIS Xcode build once, but it failed at loading Xcode project time.
So, if you want to build QGIS on Mac environment, I think that "Qt
Creator" is the
only choice. (But, I still don't try it yet...)
Probably, the following page is useful.
https://github.com/OSGeo/homebrew-osgeo4mac/wiki/Developing-on-QGIS-using-OSGeo4Mac
Regards,
Ko
> 在 2015年9月7日,上午9:45,Ko Nagase <nagase at georepublic.co.jp> 写道:
> Hi Jacory,
> I encountered the similar issue on my Mac OSX homebrew environment,
> and at that time, the cause was the difference of compiled Qt version
> (4.8.7) and loaded Qt version (4.8.6).
> https://github.com/OSGeo/homebrew-osgeo4mac/issues/95
> If you follow the QGIS MSVC build instruction, could you try to launch
> "qgis.2.9.0.sln" from command prompt after executing the environment
> variables batch file,
> then run(debug) "qgis" project after setting it as "Startup project" ?
> (Because I think that launching the project after executing the batch file
> will guarantee
> to load same Qt library as compiled one.)
> Regards,
> Ko
> 2015-09-07 9:56 GMT+09:00 Jacory <jacorygao at outlook.com>:
>> Hi,
>> This is my second time writing to you, and my problem remains. I need
>> help, thank you.
>> I’m compiling QGis 2.9 on windows 10 platform, and when it was done, I
>> found there’re some buttons don’t have icon images. But I checked the
>> qgisapp ui file, there were image sources and the image files were just
>> there too.
>> Why is that?
>> Hope someone can help me with this problem, thanks a lot.
>> This is my qgis desktop looks like
>> <QQ截图20150905145144.png>
>> Sincerely
>> Jacory Gao
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Ko Nagase (長瀬 興)
> Georepublic Japan
> mail: nagase at georepublic.co.jp
> web: http://georepublic.co.jp
Ko Nagase (長瀬 興)
Georepublic Japan
