[Qgis-developer] Deliberate errors, but Travis passes
Matthias Kuhn matthias at opengis.ch
Tue Sep 8 06:07:20 PDT 2015
Hi Tom,
I mostly use the normal assert or one of its unittest twins
https://docs.python.org/2/library/unittest.html#assert-methods to
compare calculated results against expected results.
I didn't find any of these in your file, so I am not sure, what exactly
should trigger a test failure there.
Matthias
On 09/08/2015 02:09 PM, Tom Chadwin wrote:
> I've implemented very basic Travis testing for the plugin qgis2web, and it's
> been working very well, catching code errors which result in Python errors.
> However, I'm now trying to expand the suite of tests to test the plugin
> against different data. The problem I have is that I now cannot get Travis
> to fail a build. I have tried adding deliberate errors which cause Python
> errors when running the plugin, but Travis still passes.
> The file with the tests is:
> https://github.com/tomchadwin/qgis2web/blob/master/test/test_qgis2web_dialog.py
> Can anyone help?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Deliberate-errors-but-Travis-passes-tp5223114.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150908/b0ec78b9/attachment-0001.pgp>
