[Qgis-developer] Updating field with a trigger
Bernhard Ströbl bernhard.stroebl at jena.de
Wed Sep 9 23:50:24 PDT 2015
Hi Yves,
I have only experience with PostgreSQL but I assume that sqlite behaves
similar. If you edit a feature in QGIS your layer is in edit mode
(allowing for undo/redo). Changes are committed only when you click on
the respective button. This results in an update statement sent to your
db which then calls your trigger. Thus field#2 is not changed when you
change #1 _in QGIS_. In order to have such behaviour AFAIK you would
have to do it in Python (which would be totally independent from the db
trigger then).
Apart from that if
field#2 = field#1 + x
then field#2 is totally redundant. You could either create a view
containing this field or create a virtual field in QGIS.
Bernhard
Am 09.09.2015 um 13:41 schrieb Yves Jacolin:
> Hello,
> I have a small project with a sqlite db. There is a layer with a trigger on a
> field #1 to calculate an addition and put the result in another field (#2).
> When I edit the initial field #1, the second field #2 is not updated in the
> form. I need to close the form and open it again to see the result.
> Do you think this is a known limitation or a bug?
> My point of view is that it is a limitation, as QGIS don't know that a trigger
> can change a value in the same feature server side.
> I don't know if QGIS should or could get an update of the data server side
> before display the form content.
> In case there is no such plan, do you think we can add some logic in a python
> script to force the form update (I can ask to Arnaud next week on this topic).
> Thanks,
> Y.
> Qgis-developer mailing list
__________ Information from ESET Mail Security, version of virus signature database 12230 (20150910) __________
The message was checked by ESET Mail Security.
http://www.eset.com
