[Qgis-developer] Vertex editor
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Sun Sep 13 14:07:50 PDT 2015
The new changes assume:
 - User always wants to move a vertex
 - Only one single vertex is selected
But in general, the node tool is also heavily used for deleting, adding and moving vertices. With the new behaviour it is a bit confusing for users how the other tasks can be done, when it gets automatically locked on a single node.
Cheers,
Saber
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Rouzaud Denis
Sent: 13 September 2015 16:17
To: richard at duif.net
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Vertex editor
On 13 Sep 2015, at 15:00, Richard Duivenvoorde <rdmailings at duif.net> wrote:
On 13-09-15 13:13, Radim Blazek wrote:
Is there a possibility to suppress vertex editor popup whenever a node
is selected?
Mmm, nice addition though!
But maybe it lacks an option to not use it :-)
Another observation: when I create a line, and use the nodetool to edit
one line, after clicking on a node, it immediately 'sticks' to the mouse
and moves. In 2.8 the vertex only get's 'selected' and after this
selecting you can move it. Is this intended behaviour?
Yes it is. Although, there will be another pre-selection state which will correspond to 2.8 behavior.
Although, on first click it will free the node.
The idea is that you don’t need to keep mouse button pressed while moving the node to allow using advanced digitising.
Marco has still some work to do in the node tool, you can follow discussion here:
http://hub.qgis.org/issues/13276
Regarding the table view, I don’t know if Marco will allow disabling it. At least, it would be nice to just hide it.
Denis
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
