[Qgis-developer] Project Snapping Options
Nathan Woodrow madmanwoo at gmail.com
Sun Sep 13 15:46:57 PDT 2015
Yeah I agree.  Not sure it makes much sense to be in the Settings menu when
it's not application wide. I would just move it to the project menu.
- Nathan
On Mon, Sep 14, 2015 at 5:16 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi,
> I just realized that the "Snapping Options" entry in the "Settings" menu
> is related to the project configuration. As such, I think it should go
> to the "Project Properties" or at least to the "Project" menu.
> I was expecting that changes in this dialog will modify the application
> settings. The application settings can be changed from the "Settings ->
> Options" menu but are overridden by the project settings. They only
> serve as defaults for newly generated projects.
> I would expect that I could either set the project settings to inherit
> from the application settings or that I could set the application
> settings to override the project settings.
> Did I miss something obvious or is the behavior strange indeed?
> -- Matthias
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150914/33159239/attachment.html>
