[Qgis-developer] Project Snapping Options
Richard Duivenvoorde
rdmailings at duif.net
Sun Sep 13 12:41:24 PDT 2015
On 13-09-15 21:16, Matthias Kuhn wrote:
> Hi,
> I just realized that the "Snapping Options" entry in the "Settings"
> menu is related to the project configuration. As such, I think it
> should go to the "Project Properties" or at least to the "Project"
> menu.
> I was expecting that changes in this dialog will modify the
> application settings. The application settings can be changed from
> the "Settings -> Options" menu but are overridden by the project
> settings. They only serve as defaults for newly generated
> projects.
> I would expect that I could either set the project settings to
> inherit from the application settings or that I could set the
> application settings to override the project settings.
> Did I miss something obvious or is the behavior strange indeed?
> -- Matthias
Hi Matthias,
I asked this questions some weeks ago [0]
Good to see that I'm not the only one getting confused :-)
We must make things more clear one way or another.
Regards,
[0
http://osgeo-org.1560.x6.nabble.com/snapping-and-snapping-options-td5213800.html]
