[Qgis-developer] Vertex editor
Denis Rouzaud denis.rouzaud at gmail.com
Sun Sep 13 22:13:26 PDT 2015
On 09/13/2015 11:07 PM, Saber Razmjooei wrote:
> The new changes assume:
>  - User always wants to move a vertex
>  - Only one single vertex is selected
> But in general, the node tool is also heavily used for deleting, adding and moving vertices. With the new behaviour it is a bit confusing for users how the other tasks can be done, when it gets automatically locked on a single node.
No, old behavior should be brought back:
- when you click on a node, it moves but you can delete directly (so no
changes in terms of click)
- selecting several nodes should put them in pre-selection mode (hence
you can delete it).
Best wishes,
Denis
> Cheers,
> Saber
> From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Rouzaud Denis
> Sent: 13 September 2015 16:17
> To: richard at duif.net
> Cc: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Vertex editor
> On 13 Sep 2015, at 15:00, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 13-09-15 13:13, Radim Blazek wrote:
> Is there a possibility to suppress vertex editor popup whenever a node
> is selected?
> Mmm, nice addition though!
> But maybe it lacks an option to not use it :-)
> Another observation: when I create a line, and use the nodetool to edit
> one line, after clicking on a node, it immediately 'sticks' to the mouse
> and moves. In 2.8 the vertex only get's 'selected' and after this
> selecting you can move it. Is this intended behaviour?
> Yes it is. Although, there will be another pre-selection state which will correspond to 2.8 behavior.
> Although, on first click it will free the node.
> The idea is that you don’t need to keep mouse button pressed while moving the node to allow using advanced digitising.
> Marco has still some work to do in the node tool, you can follow discussion here:
> http://hub.qgis.org/issues/13276
> Regarding the table view, I don’t know if Marco will allow disabling it. At least, it would be nice to just hide it.
> Denis
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
> by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
> that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
> such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> Qgis-developer mailing list
