[Qgis-developer] Vertex editor
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Sep 14 19:30:15 PDT 2015
Hi all
Considering the discussion, I think it is best if I revert the
click-click changes. Like that, there will be vertex editor with old
click-drag behaviour. The remaining issues can then wait until after 26th.
Greetings from foss4g,
Marco
Am 14.09.2015 um 07:26 schrieb Mathieu Pellerin:
> At the risk of stating the obvious, selecting multiple nodes (to move
> or delete those) has to come back. I do lots of digitizing and
> shipping 2.12 in its current state would be a very significant regression.
> M
> On 14 Sep 2015 12:13 pm, "Denis Rouzaud" <denis.rouzaud at gmail.com
> <mailto:denis.rouzaud at gmail.com>> wrote:
> On 09/13/2015 11:07 PM, Saber Razmjooei wrote:
> > The new changes assume:
> > - User always wants to move a vertex
> > - Only one single vertex is selected
> > But in general, the node tool is also heavily used for deleting,
> adding and moving vertices. With the new behaviour it is a bit
> confusing for users how the other tasks can be done, when it gets
> automatically locked on a single node.
> No, old behavior should be brought back:
> - when you click on a node, it moves but you can delete directly
> (so no
> changes in terms of click)
> - selecting several nodes should put them in pre-selection mode (hence
> you can delete it).
> Best wishes,
> Denis
> > Cheers,
> > Saber
> > From: qgis-developer-bounces at lists.osgeo.org
> <mailto:qgis-developer-bounces at lists.osgeo.org>
> [mailto:qgis-developer-bounces at lists.osgeo.org
> <mailto:qgis-developer-bounces at lists.osgeo.org>] On Behalf Of
> Rouzaud Denis
> > Sent: 13 September 2015 16:17
> > To: richard at duif.net <mailto:richard at duif.net>
> > Cc: qgis-developer at lists.osgeo.org
> <mailto:qgis-developer at lists.osgeo.org>
> > Subject: Re: [Qgis-developer] Vertex editor
> > On 13 Sep 2015, at 15:00, Richard Duivenvoorde
> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
> > On 13-09-15 13:13, Radim Blazek wrote:
> > Is there a possibility to suppress vertex editor popup whenever
> a node
> > is selected?
> > Mmm, nice addition though!
> > But maybe it lacks an option to not use it :-)
> > Another observation: when I create a line, and use the nodetool
> to edit
> > one line, after clicking on a node, it immediately 'sticks' to
> the mouse
> > and moves. In 2.8 the vertex only get's 'selected' and after this
> > selecting you can move it. Is this intended behaviour?
> > Yes it is. Although, there will be another pre-selection state
> which will correspond to 2.8 behavior.
> > Although, on first click it will free the node.
> > The idea is that you don’t need to keep mouse button pressed
> while moving the node to allow using advanced digitising.
> > Marco has still some work to do in the node tool, you can follow
> discussion here:
> > http://hub.qgis.org/issues/13276
> > Regarding the table view, I don’t know if Marco will allow
> disabling it. At least, it would be nice to just hide it.
> > Denis
> > This email and any files transmitted with it are confidential
> and intended solely for the use of the individual or entity to
> whom they are addressed.
> > If you have received this email in error please notify the
> system manager. This message contains confidential information and
> is intended only for the
> > individual named. If you are not the named addressee you should
> not disseminate, distribute or copy this e-mail. Please notify the
> sender immediately
> > by e-mail if you have received this e-mail by mistake and delete
> this e-mail from your system. If you are not the intended
> recipient you are notified
> > that disclosing, copying, distributing or taking any action in
> reliance on the contents of this information is strictly prohibited.
> > Whilst reasonable care has been taken to avoid virus
> transmission, no responsibility for viruses is taken and it is
> your responsibility to carry out
> > such checks as you feel appropriate.
> > If this email contains a quote or offer to sell products, carry
> out work or perform services then our standard terms and
> conditions (which can be found at
> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf
> shall apply unless explicitly stated otherwise.
> > Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> <mailto:Qgis-developer at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150915/f0876aed/attachment.html>
