[Qgis-developer] Vertex editor
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Sep 14 22:21:23 PDT 2015
On 09/15/2015 04:30 AM, Marco Hugentobler wrote:
> Hi all
> Considering the discussion, I think it is best if I revert the
> click-click changes. Like that, there will be vertex editor with old
> click-drag behaviour. The remaining issues can then wait until after 26th.
It's a bit of a pity.
We discussed the new functionnality of the node tool, and it was decided
to integrate at once the node editor and the advanced digitizing.
> Greetings from foss4g,
> Marco
> Am 14.09.2015 um 07:26 schrieb Mathieu Pellerin:
>> At the risk of stating the obvious, selecting multiple nodes (to move
>> or delete those) has to come back. I do lots of digitizing and
>> shipping 2.12 in its current state would be a very significant regression.
>> M
>> On 14 Sep 2015 12:13 pm, "Denis Rouzaud" <denis.rouzaud at gmail.com
>> <mailto:denis.rouzaud at gmail.com>> wrote:
>> On 09/13/2015 11:07 PM, Saber Razmjooei wrote:
>> > The new changes assume:
>> > - User always wants to move a vertex
>> > - Only one single vertex is selected
>> > But in general, the node tool is also heavily used for deleting,
>> adding and moving vertices. With the new behaviour it is a bit
>> confusing for users how the other tasks can be done, when it gets
>> automatically locked on a single node.
>> No, old behavior should be brought back:
>> - when you click on a node, it moves but you can delete directly
>> (so no
>> changes in terms of click)
>> - selecting several nodes should put them in pre-selection mode (hence
>> you can delete it).
>> Best wishes,
>> Denis
>> > Cheers,
>> > Saber
>> > From: qgis-developer-bounces at lists.osgeo.org
>> <mailto:qgis-developer-bounces at lists.osgeo.org>
>> [mailto:qgis-developer-bounces at lists.osgeo.org
>> <mailto:qgis-developer-bounces at lists.osgeo.org>] On Behalf Of
>> Rouzaud Denis
>> > Sent: 13 September 2015 16:17
>> > To: richard at duif.net <mailto:richard at duif.net>
>> > Cc: qgis-developer at lists.osgeo.org
>> <mailto:qgis-developer at lists.osgeo.org>
>> > Subject: Re: [Qgis-developer] Vertex editor
>> > On 13 Sep 2015, at 15:00, Richard Duivenvoorde
>> <<mailto:rdmailings at duif.net>rdmailings at duif.net> wrote:
>> > On 13-09-15 13:13, Radim Blazek wrote:
>> > Is there a possibility to suppress vertex editor popup whenever
>> a node
>> > is selected?
>> > Mmm, nice addition though!
>> > But maybe it lacks an option to not use it :-)
>> > Another observation: when I create a line, and use the nodetool
>> to edit
>> > one line, after clicking on a node, it immediately 'sticks' to
>> the mouse
>> > and moves. In 2.8 the vertex only get's 'selected' and after this
>> > selecting you can move it. Is this intended behaviour?
>> > Yes it is. Although, there will be another pre-selection state
>> which will correspond to 2.8 behavior.
>> > Although, on first click it will free the node.
>> > The idea is that you don’t need to keep mouse button pressed
>> while moving the node to allow using advanced digitising.
>> > Marco has still some work to do in the node tool, you can follow
>> discussion here:
>> > http://hub.qgis.org/issues/13276
>> > Regarding the table view, I don’t know if Marco will allow
>> disabling it. At least, it would be nice to just hide it.
>> > Denis
>> > This email and any files transmitted with it are confidential
>> and intended solely for the use of the individual or entity to
>> whom they are addressed.
>> > If you have received this email in error please notify the
>> system manager. This message contains confidential information and
>> is intended only for the
>> > individual named. If you are not the named addressee you should
>> not disseminate, distribute or copy this e-mail. Please notify the
>> sender immediately
>> > by e-mail if you have received this e-mail by mistake and delete
>> this e-mail from your system. If you are not the intended
>> recipient you are notified
>> > that disclosing, copying, distributing or taking any action in
>> reliance on the contents of this information is strictly prohibited.
>> > Whilst reasonable care has been taken to avoid virus
>> transmission, no responsibility for viruses is taken and it is
>> your responsibility to carry out
>> > such checks as you feel appropriate.
>> > If this email contains a quote or offer to sell products, carry
>> out work or perform services then our standard terms and
>> conditions (which can be found at
>> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf
>> shall apply unless explicitly stated otherwise.
>> > Saber Razmjooei and Peter Wells trading as Lutra Consulting.
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
