[Qgis-developer] Vertex editor
Nathan Woodrow
madmanwoo at gmail.com
Mon Sep 14 22:24:55 PDT 2015
Only if it works though and doesn't make editing worse which is the current
case. The large amount of regressions need to be fixed or else people are
going to get super annoyed at not being able to edit correctly and I can
tell you that is going to be a lot of people. Reverting is good move
unless there is time to fix the bugs which doesn't seem to be the case.
Regards,
On Tue, Sep 15, 2015 at 3:21 PM, Denis Rouzaud <denis.rouzaud at gmail.com>
wrote:
> On 09/15/2015 04:30 AM, Marco Hugentobler wrote:
> > Hi all
> > Considering the discussion, I think it is best if I revert the
> > click-click changes. Like that, there will be vertex editor with old
> > click-drag behaviour. The remaining issues can then wait until after
> 26th.
> It's a bit of a pity.
> We discussed the new functionnality of the node tool, and it was decided
> to integrate at once the node editor and the advanced digitizing.
> > Greetings from foss4g,
> > Marco
> > Am 14.09.2015 um 07:26 schrieb Mathieu Pellerin:
> >> At the risk of stating the obvious, selecting multiple nodes (to move
> >> or delete those) has to come back. I do lots of digitizing and
> >> shipping 2.12 in its current state would be a very significant
> regression.
> >> M
> >> On 14 Sep 2015 12:13 pm, "Denis Rouzaud" <denis.rouzaud at gmail.com
> >> <mailto:denis.rouzaud at gmail.com>> wrote:
> >> On 09/13/2015 11:07 PM, Saber Razmjooei wrote:
> >> > The new changes assume:
> >> > - User always wants to move a vertex
> >> > - Only one single vertex is selected
> >> > But in general, the node tool is also heavily used for deleting,
> >> adding and moving vertices. With the new behaviour it is a bit
> >> confusing for users how the other tasks can be done, when it gets
> >> automatically locked on a single node.
> >> No, old behavior should be brought back:
> >> - when you click on a node, it moves but you can delete directly
> >> (so no
> >> changes in terms of click)
> >> - selecting several nodes should put them in pre-selection mode
> (hence
> >> you can delete it).
> >> Best wishes,
> >> Denis
> >> > Cheers,
> >> > Saber
> >> > From: qgis-developer-bounces at lists.osgeo.org
> >> <mailto:qgis-developer-bounces at lists.osgeo.org>
> >> [mailto:qgis-developer-bounces at lists.osgeo.org
> >> <mailto:qgis-developer-bounces at lists.osgeo.org>] On Behalf Of
> >> Rouzaud Denis
> >> > Sent: 13 September 2015 16:17
> >> > To: richard at duif.net <mailto:richard at duif.net>
> >> > Cc: qgis-developer at lists.osgeo.org
> >> <mailto:qgis-developer at lists.osgeo.org>
> >> > Subject: Re: [Qgis-developer] Vertex editor
> >> > On 13 Sep 2015, at 15:00, Richard Duivenvoorde
> >> <<mailto:rdmailings at duif.net>rdmailings at duif.net> wrote:
> >> > On 13-09-15 13:13, Radim Blazek wrote:
> >> > Is there a possibility to suppress vertex editor popup whenever
> >> a node
> >> > is selected?
> >> > Mmm, nice addition though!
> >> > But maybe it lacks an option to not use it :-)
> >> > Another observation: when I create a line, and use the nodetool
> >> to edit
> >> > one line, after clicking on a node, it immediately 'sticks' to
> >> the mouse
> >> > and moves. In 2.8 the vertex only get's 'selected' and after this
> >> > selecting you can move it. Is this intended behaviour?
> >> > Yes it is. Although, there will be another pre-selection state
> >> which will correspond to 2.8 behavior.
> >> > Although, on first click it will free the node.
> >> > The idea is that you don’t need to keep mouse button pressed
> >> while moving the node to allow using advanced digitising.
> >> > Marco has still some work to do in the node tool, you can follow
> >> discussion here:
> >> > http://hub.qgis.org/issues/13276
> >> > Regarding the table view, I don’t know if Marco will allow
> >> disabling it. At least, it would be nice to just hide it.
> >> > Denis
> >> > This email and any files transmitted with it are confidential
> >> and intended solely for the use of the individual or entity to
> >> whom they are addressed.
> >> > If you have received this email in error please notify the
> >> system manager. This message contains confidential information and
> >> is intended only for the
> >> > individual named. If you are not the named addressee you should
> >> not disseminate, distribute or copy this e-mail. Please notify the
> >> sender immediately
> >> > by e-mail if you have received this e-mail by mistake and delete
> >> this e-mail from your system. If you are not the intended
> >> recipient you are notified
> >> > that disclosing, copying, distributing or taking any action in
> >> reliance on the contents of this information is strictly prohibited.
> >> > Whilst reasonable care has been taken to avoid virus
> >> transmission, no responsibility for viruses is taken and it is
> >> your responsibility to carry out
> >> > such checks as you feel appropriate.
> >> > If this email contains a quote or offer to sell products, carry
> >> out work or perform services then our standard terms and
> >> conditions (which can be found at
> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf
> >> shall apply unless explicitly stated otherwise.
> >> > Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> >> > _______________________________________________
> >> > Qgis-developer mailing list
> >> > Qgis-developer at lists.osgeo.org
> >> <mailto:Qgis-developer at lists.osgeo.org>
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Qgis-developer at lists.osgeo.org <mailto:
> > Dr. Marco Hugentobler
> > Sourcepole - Linux & Open Source Solutions
> > Weberstrasse 5, CH-8004 Zürich, Switzerland
> > marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> > Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150915/a7050c6c/attachment-0001.html>
