[Qgis-developer] Vertex editor
Denis Rouzaud denis.rouzaud at gmail.com
Mon Sep 14 23:17:59 PDT 2015
Yes, I understand.
I'm just afraid to never get the advanced digitizing in the node tool as
originaly planned.
I totally agree that having the node tool broken for such a long time in
master was not really a good situation.
On 09/15/2015 07:24 AM, Nathan Woodrow wrote:
> Only if it works though and doesn't make editing worse which is the
> current case.  The large amount of regressions need to be fixed or else
> people are going to get super annoyed at not being able to edit
> correctly and I can tell you that is going to be a lot of people.
> Reverting is good move unless there is time to fix the bugs which
> doesn't seem to be the case.
> Regards,
> On Tue, Sep 15, 2015 at 3:21 PM, Denis Rouzaud <denis.rouzaud at gmail.com
> <mailto:denis.rouzaud at gmail.com>> wrote:
>     On 09/15/2015 04:30 AM, Marco Hugentobler wrote:
>     > Hi all
>     > Considering the discussion, I think it is best if I revert the
>     > click-click changes. Like that, there will be vertex editor with old
>     > click-drag behaviour. The remaining issues can then wait until after 26th.
>     It's a bit of a pity.
>     We discussed the new functionnality of the node tool, and it was decided
>     to integrate at once the node editor and the advanced digitizing.
>     > Greetings from foss4g,
>     > Marco
>     > Am 14.09.2015 um 07:26 schrieb Mathieu Pellerin:
>     >> At the risk of stating the obvious, selecting multiple nodes (to move
>     >> or delete those) has to come back. I do lots of digitizing and
>     >> shipping 2.12 in its current state would be a very significant regression.
>     >> M
>     >> On 14 Sep 2015 12:13 pm, "Denis Rouzaud" <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>
>     >> <mailto:denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>>> wrote:
>     >>     On 09/13/2015 11:07 PM, Saber Razmjooei wrote:
>     >>     > The new changes assume:
>     >>     >  - User always wants to move a vertex
>     >>     >  - Only one single vertex is selected
>     >>     > But in general, the node tool is also heavily used for deleting,
>     >>     adding and moving vertices. With the new behaviour it is a bit
>     >>     confusing for users how the other tasks can be done, when it gets
>     >>     automatically locked on a single node.
>     >>     No, old behavior should be brought back:
>     >>     - when you click on a node, it moves but you can delete directly
>     >>     (so no
>     >>     changes in terms of click)
>     >>     - selecting several nodes should put them in pre-selection mode (hence
>     >>     you can delete it).
>     >>     Best wishes,
>     >>     Denis
>     >>     > Cheers,
>     >>     > Saber
>     >>     > From: qgis-developer-bounces at lists.osgeo.org
>     <mailto:qgis-developer-bounces at lists.osgeo.org>
>     <mailto:qgis-developer-bounces at lists.osgeo.org>>
>     >>     [mailto:qgis-developer-bounces at lists.osgeo.org
>     <mailto:qgis-developer-bounces at lists.osgeo.org>>] On Behalf Of
>     >>     Rouzaud Denis
>     >>     > Sent: 13 September 2015 16:17
>     >>     > To: richard at duif.net <mailto:richard at duif.net>
>     <mailto:richard at duif.net <mailto:richard at duif.net>>
>     >>     > Cc: qgis-developer at lists.osgeo.org
>     <mailto:qgis-developer at lists.osgeo.org>
>     <mailto:qgis-developer at lists.osgeo.org>>
>     >>     > Subject: Re: [Qgis-developer] Vertex editor
>     >>     > On 13 Sep 2015, at 15:00, Richard Duivenvoorde
>     >>     <<mailto:rdmailings at duif.net
>     <mailto:rdmailings at duif.net>>rdmailings at duif.net
>     <mailto:rdmailings at duif.net>> wrote:
>     >>     > On 13-09-15 <tel:13-09-15> 13:13, Radim Blazek wrote:
>     >>     > Is there a possibility to suppress vertex editor popup whenever
>     >>     a node
>     >>     > is selected?
>     >>     > Mmm, nice addition though!
>     >>     > But maybe it lacks an option to not use it :-)
>     >>     > Another observation: when I create a line, and use the nodetool
>     >>     to edit
>     >>     > one line, after clicking on a node, it immediately 'sticks' to
>     >>     the mouse
>     >>     > and moves. In 2.8 the vertex only get's 'selected' and
>     after this
>     >>     > selecting you can move it. Is this intended behaviour?
>     >>     > Yes it is. Although, there will be another pre-selection state
>     >>     which will correspond to 2.8 behavior.
>     >>     > Although, on first click it will free the node.
>     >>     > The idea is that you don’t need to keep mouse button pressed
>     >>     while moving the node to allow using advanced digitising.
>     >>     > Marco has still some work to do in the node tool, you can
>     follow
>     >>     discussion here:
>     >>     > http://hub.qgis.org/issues/13276
>     >>     > Regarding the table view, I don’t know if Marco will allow
>     >>     disabling it. At least, it would be nice to just hide it.
>     >>     > Denis
>     >>     > This email and any files transmitted with it are confidential
>     >>     and intended solely for the use of the individual or entity to
>     >>     whom they are addressed.
>     >>     > If you have received this email in error please notify the
>     >>     system manager. This message contains confidential
>     information and
>     >>     is intended only for the
>     >>     > individual named. If you are not the named addressee you should
>     >>     not disseminate, distribute or copy this e-mail. Please
>     notify the
>     >>     sender immediately
>     >>     > by e-mail if you have received this e-mail by mistake and
>     delete
>     >>     this e-mail from your system. If you are not the intended
>     >>     recipient you are notified
>     >>     > that disclosing, copying, distributing or taking any action in
>     >>     reliance on the contents of this information is strictly
>     prohibited.
>     >>     > Whilst reasonable care has been taken to avoid virus
>     >>     transmission, no responsibility for viruses is taken and it is
>     >>     your responsibility to carry out
>     >>     > such checks as you feel appropriate.
>     >>     > If this email contains a quote or offer to sell products, carry
>     >>     out work or perform services then our standard terms and
>     >>     conditions (which can be found at
>      http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf
>     >>     shall apply unless explicitly stated otherwise.
>     >>     > Saber Razmjooei and Peter Wells trading as Lutra Consulting.
>     >>     > _______________________________________________
>     >>     > Qgis-developer mailing list
>     >>     > Qgis-developer at lists.osgeo.org
>     <mailto:Qgis-developer at lists.osgeo.org>
>     <mailto:Qgis-developer at lists.osgeo.org>>
>     >>     > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     > Dr. Marco Hugentobler
>     > Sourcepole -  Linux & Open Source Solutions
>     > Weberstrasse 5, CH-8004 Zürich, Switzerland
>     > marco.hugentobler at sourcepole.ch
>     <mailto:marco.hugentobler at sourcepole.ch> http://www.sourcepole.ch
>     > Technical Advisor QGIS Project Steering Committee
>     > Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
