[Qgis-developer] Vertex editor
Marco Hugentobler marco.hugentobler at sourcepole.ch
Tue Sep 15 23:03:09 PDT 2015
Am 15.09.2015 um 04:30 schrieb Marco Hugentobler:
> Hi all
> Considering the discussion, I think it is best if I revert the
> click-click changes. Like that, there will be vertex editor with old
> click-drag behaviour. The remaining issues can then wait until after 26th.
Done now in master branch.
Regards,
Marco
> Greetings from foss4g,
> Marco
> Am 14.09.2015 um 07:26 schrieb Mathieu Pellerin:
>> At the risk of stating the obvious, selecting multiple nodes (to move
>> or delete those) has to come back. I do lots of digitizing and
>> shipping 2.12 in its current state would be a very significant
>> regression.
>> M
>> On 14 Sep 2015 12:13 pm, "Denis Rouzaud" <denis.rouzaud at gmail.com
>> <mailto:denis.rouzaud at gmail.com>> wrote:
>>     On 09/13/2015 11:07 PM, Saber Razmjooei wrote:
>>     > The new changes assume:
>>     >  - User always wants to move a vertex
>>     >  - Only one single vertex is selected
>>     > But in general, the node tool is also heavily used for
>>     deleting, adding and moving vertices. With the new behaviour it
>>     is a bit confusing for users how the other tasks can be done,
>>     when it gets automatically locked on a single node.
>>     No, old behavior should be brought back:
>>     - when you click on a node, it moves but you can delete directly
>>     (so no
>>     changes in terms of click)
>>     - selecting several nodes should put them in pre-selection mode
>>     (hence
>>     you can delete it).
>>     Best wishes,
>>     Denis
>>     > Cheers,
>>     > Saber
>>     > From: qgis-developer-bounces at lists.osgeo.org
>>     <mailto:qgis-developer-bounces at lists.osgeo.org>
>>     [mailto:qgis-developer-bounces at lists.osgeo.org
>>     <mailto:qgis-developer-bounces at lists.osgeo.org>] On Behalf Of
>>     Rouzaud Denis
>>     > Sent: 13 September 2015 16:17
>>     > To: richard at duif.net <mailto:richard at duif.net>
>>     > Cc: qgis-developer at lists.osgeo.org
>>     <mailto:qgis-developer at lists.osgeo.org>
>>     > Subject: Re: [Qgis-developer] Vertex editor
>>     > On 13 Sep 2015, at 15:00, Richard Duivenvoorde
>>     <rdmailings at duif.net> wrote:
>>     > On 13-09-15 13:13, Radim Blazek wrote:
>>     > Is there a possibility to suppress vertex editor popup whenever
>>     a node
>>     > is selected?
>>     > Mmm, nice addition though!
>>     > But maybe it lacks an option to not use it :-)
>>     > Another observation: when I create a line, and use the nodetool
>>     to edit
>>     > one line, after clicking on a node, it immediately 'sticks' to
>>     the mouse
>>     > and moves. In 2.8 the vertex only get's 'selected' and after this
>>     > selecting you can move it. Is this intended behaviour?
>>     > Yes it is. Although, there will be another pre-selection state
>>     which will correspond to 2.8 behavior.
>>     > Although, on first click it will free the node.
>>     > The idea is that you don’t need to keep mouse button pressed
>>     while moving the node to allow using advanced digitising.
>>     > Marco has still some work to do in the node tool, you can
>>     follow discussion here:
>>     > http://hub.qgis.org/issues/13276
>>     > Regarding the table view, I don’t know if Marco will allow
>>     disabling it. At least, it would be nice to just hide it.
>>     > Denis
>>     > This email and any files transmitted with it are confidential
>>     and intended solely for the use of the individual or entity to
>>     whom they are addressed.
>>     > If you have received this email in error please notify the
>>     system manager. This message contains confidential information
>>     and is intended only for the
>>     > individual named. If you are not the named addressee you should
>>     not disseminate, distribute or copy this e-mail. Please notify
>>     the sender immediately
>>     > by e-mail if you have received this e-mail by mistake and
>>     delete this e-mail from your system. If you are not the intended
>>     recipient you are notified
>>     > that disclosing, copying, distributing or taking any action in
>>     reliance on the contents of this information is strictly prohibited.
>>     > Whilst reasonable care has been taken to avoid virus
>>     transmission, no responsibility for viruses is taken and it is
>>     your responsibility to carry out
>>     > such checks as you feel appropriate.
>>     > If this email contains a quote or offer to sell products, carry
>>     out work or perform services then our standard terms and
>>     conditions (which can be found at
>>     http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf
>>     shall apply unless explicitly stated otherwise.
>>     > Saber Razmjooei and Peter Wells trading as Lutra Consulting.
>>     > _______________________________________________
>>     > Qgis-developer mailing list
>>     > Qgis-developer at lists.osgeo.org
>>     <mailto:Qgis-developer at lists.osgeo.org>
>>     > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch  http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150916/9202101a/attachment.html>
