[Qgis-developer] SVG fill broken?
Andreas Neumann
a.neumann at carto.net
Tue Sep 15 00:30:06 PDT 2015
Hi Paolo,
It seems like there is no valid file path selected pointing to your SVG
file. Below the symbol preview panel there is a line (just above the
"effeti disegno" checkbox) that normally shows the file path pointing
towards the selected SVG file. In your case it seems to be empty - but
it shouldn't.
See my screenshot at http://webgis.uster.ch/temp/qgis_svg_fill.png
Can you try to select a file and see how it behaves?
Is this a project migrated from an older version?
Andreas
On 15.09.2015 09:12, Paolo Cavallini wrote:
> Il 14/09/2015 20:24, Andreas Neumann ha scritto:
>> can you perhaps share a screenshot of the problem and the settings?
> Hi Andreas,
> here it is:
> http://www.faunalia.eu/~paolo/svg_fill.png
> Thanks.
