[Qgis-developer] SVG fill broken?
Mathieu Pellerin nirvn.asia at gmail.com
Tue Sep 15 00:33:54 PDT 2015
The SVG fill issue was raised >11 months ago here:
http://hub.qgis.org/issues/11522
It only affects QGIS on 64-bit platform (all OSes).
M
On Tue, Sep 15, 2015 at 2:30 PM, Andreas Neumann <a.neumann at carto.net>
wrote:
> Hi Paolo,
> It seems like there is no valid file path selected pointing to your SVG
> file. Below the symbol preview panel there is a line (just above the
> "effeti disegno" checkbox) that normally shows the file path pointing
> towards the selected SVG file. In your case it seems to be empty - but it
> shouldn't.
> See my screenshot at http://webgis.uster.ch/temp/qgis_svg_fill.png
> Can you try to select a file and see how it behaves?
> Is this a project migrated from an older version?
> Andreas
> On 15.09.2015 09:12, Paolo Cavallini wrote:
>> Il 14/09/2015 20:24, Andreas Neumann ha scritto:
>>> can you perhaps share a screenshot of the problem and the settings?
>> Hi Andreas,
>> here it is:
>> http://www.faunalia.eu/~paolo/svg_fill.png
>> Thanks.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150915/e211757d/attachment.html>
