[Qgis-developer] SVG fill broken?
Andreas Neumann a.neumann at carto.net
Tue Sep 15 01:00:08 PDT 2015
Not sure if this is the same issue.
In Paolos case, the symbol path is really empty (no file path set). Even
if you select a default symbol there should be something visible in the
file path line input widget. So either the user never selected an SVG
symbol (which would explain it), or there is a migration issue from an
older QGIS version.
On the other issue (http://hub.qgis.org/issues/11522):
I can confirm that the default fill of default symbols is white on a
64bit Ubuntu Linux and recent master. Hopefully, this can be fixed. It
is quite annoying - but not a major blocker in my opinion - as the user
can still easily fix it by setting the color back to black.
Andreas
On 15.09.2015 09:33, Mathieu Pellerin wrote:
> The SVG fill issue was raised >11 months ago here:
> It only affects QGIS on 64-bit platform (all OSes).
> M
> On Tue, Sep 15, 2015 at 2:30 PM, Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
>     Hi Paolo,
>     It seems like there is no valid file path selected pointing to
>     your SVG file. Below the symbol preview panel there is a line
>     (just above the "effeti disegno" checkbox) that normally shows the
>     file path pointing towards the selected SVG file. In your case it
>     seems to be empty - but it shouldn't.
>     See my screenshot at http://webgis.uster.ch/temp/qgis_svg_fill.png
>     Can you try to select a file and see how it behaves?
>     Is this a project migrated from an older version?
>     Andreas
>     On 15.09.2015 09:12, Paolo Cavallini wrote:
>         Il 14/09/2015 20:24, Andreas Neumann ha scritto:
>             can you perhaps share a screenshot of the problem and the
>             settings?
>         Hi Andreas,
>         here it is:
>         http://www.faunalia.eu/~paolo/svg_fill.png
>         <http://www.faunalia.eu/%7Epaolo/svg_fill.png>
>         Thanks.
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150915/21f90d1a/attachment-0001.html>
