[Qgis-developer] SVG fill broken?
Andreas Neumann
a.neumann at carto.net
Tue Sep 15 01:05:11 PDT 2015
Actually I just had a look at the symbols with the white fill and it
seems that the actual symbols have the fill set to white:
As an example:
In file svg/accommodation/accommodation_caravan_park.svg Konsole
outputsvg/accommodation/accommodation_caravan_park.svg
Konsole output
<path fill="param(fill) #FFF"stroke="param(outline) #000"
FFF means a white fill.
So it seems that the 64bit software is correct and the 32bit software
would be broken if it still renders this as black (which I doubt it
does), but the symbol definition is broken. That doesn't even require a
developer to fix - any user can do that.
I don't know who changed all these default fills to white?
I'll just add this as a note to the bug description.
Andreas
On 15.09.2015 09:33, Mathieu Pellerin wrote:
> The SVG fill issue was raised >11 months ago here:
> http://hub.qgis.org/issues/11522
> It only affects QGIS on 64-bit platform (all OSes).
> M
> On Tue, Sep 15, 2015 at 2:30 PM, Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
> Hi Paolo,
> It seems like there is no valid file path selected pointing to
> your SVG file. Below the symbol preview panel there is a line
> (just above the "effeti disegno" checkbox) that normally shows the
> file path pointing towards the selected SVG file. In your case it
> seems to be empty - but it shouldn't.
> See my screenshot at http://webgis.uster.ch/temp/qgis_svg_fill.png
> Can you try to select a file and see how it behaves?
> Is this a project migrated from an older version?
> Andreas
> On 15.09.2015 09:12, Paolo Cavallini wrote:
> Il 14/09/2015 20:24, Andreas Neumann ha scritto:
> can you perhaps share a screenshot of the problem and the
> settings?
> Hi Andreas,
> here it is:
> http://www.faunalia.eu/~paolo/svg_fill.png
> <http://www.faunalia.eu/%7Epaolo/svg_fill.png>
> Thanks.
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150915/7c375c01/attachment.html>
