[Qgis-developer] SVG fill broken?
Mathieu Pellerin nirvn.asia at gmail.com
Tue Sep 15 01:08:41 PDT 2015
Andreas, shouldn't param(fill) mean that it'd be replaced by the default
value (which would be black, or at least is under 32-bit)?
On Tue, Sep 15, 2015 at 3:05 PM, Andreas Neumann <a.neumann at carto.net>
wrote:
> Actually I just had a look at the symbols with the white fill and it seems
> that the actual symbols have the fill set to white:
> As an example:
> In file svg/accommodation/accommodation_caravan_park.svg
> <path fill="param(fill) #FFF" stroke="param(outline) #000"
> FFF means a white fill.
> So it seems that the 64bit software is correct and the 32bit software
> would be broken if it still renders this as black (which I doubt it does),
> but the symbol definition is broken. That doesn't even require a developer
> to fix - any user can do that.
> I don't know who changed all these default fills to white?
> I'll just add this as a note to the bug description.
> Andreas
> On 15.09.2015 09:33, Mathieu Pellerin wrote:
> The SVG fill issue was raised >11 months ago here:
> <http://hub.qgis.org/issues/11522>http://hub.qgis.org/issues/11522
> It only affects QGIS on 64-bit platform (all OSes).
> M
> On Tue, Sep 15, 2015 at 2:30 PM, Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Hi Paolo,
>> It seems like there is no valid file path selected pointing to your SVG
>> file. Below the symbol preview panel there is a line (just above the
>> "effeti disegno" checkbox) that normally shows the file path pointing
>> towards the selected SVG file. In your case it seems to be empty - but it
>> shouldn't.
>> See my screenshot at http://webgis.uster.ch/temp/qgis_svg_fill.png
>> Can you try to select a file and see how it behaves?
>> Is this a project migrated from an older version?
>> Andreas
>> On 15.09.2015 09:12, Paolo Cavallini wrote:
>>> Il 14/09/2015 20:24, Andreas Neumann ha scritto:
>>>> can you perhaps share a screenshot of the problem and the settings?
>>> Hi Andreas,
>>> here it is:
>>> http://www.faunalia.eu/~paolo/svg_fill.png
>>> Thanks.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150915/a035ada3/attachment.html>
