[Qgis-developer] SVG fill broken?
Andreas Neumann a.neumann at carto.net
Tue Sep 15 01:25:41 PDT 2015
Yes - param(fill) means that this fill color is replacable. But it is
followed by the default color. #FFF means 255,255,255 which is white.
So the 64bit version renders this correctly. If the 32bit version
renders this as black it is wrong.
Someone must have changed all this fill colors to white in the past. We
must change this back to black (#000)
Andreas
On 15.09.2015 10:08, Mathieu Pellerin wrote:
> Andreas, shouldn't param(fill) mean that it'd be replaced by the
> default value (which would be black, or at least is under 32-bit)?
> On Tue, Sep 15, 2015 at 3:05 PM, Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
>     Actually I just had a look at the symbols with the white fill and
>     it seems that the actual symbols have the fill set to white:
>     As an example:
>     In file svg/accommodation/accommodation_caravan_park.svg
>     <path fill="param(fill) #FFF"stroke="param(outline) #000"
>     FFF means a white fill.
>     So it seems that the 64bit software is correct and the 32bit
>     software would be broken if it still renders this as black (which
>     I doubt it does), but the symbol definition is broken. That
>     doesn't even require a developer to fix - any user can do that.
>     I don't know who changed all these default fills to white?
>     I'll just add this as a note to the bug description.
>     Andreas
>     On 15.09.2015 09:33, Mathieu Pellerin wrote:
>>     The SVG fill issue was raised >11 months ago here:
>>     http://hub.qgis.org/issues/11522
>>     It only affects QGIS on 64-bit platform (all OSes).
>>     M
>>     On Tue, Sep 15, 2015 at 2:30 PM, Andreas Neumann
>>     <a.neumann at carto.net <mailto:a.neumann at carto.net>> wrote:
>>         Hi Paolo,
>>         It seems like there is no valid file path selected pointing
>>         to your SVG file. Below the symbol preview panel there is a
>>         line (just above the "effeti disegno" checkbox) that normally
>>         shows the file path pointing towards the selected SVG file.
>>         In your case it seems to be empty - but it shouldn't.
>>         See my screenshot at
>>         http://webgis.uster.ch/temp/qgis_svg_fill.png
>>         Can you try to select a file and see how it behaves?
>>         Is this a project migrated from an older version?
>>         Andreas
>>         On 15.09.2015 09:12, Paolo Cavallini wrote:
>>             Il 14/09/2015 20:24, Andreas Neumann ha scritto:
>>                 can you perhaps share a screenshot of the problem and
>>                 the settings?
>>             Hi Andreas,
>>             here it is:
>>             http://www.faunalia.eu/~paolo/svg_fill.png
>>             <http://www.faunalia.eu/%7Epaolo/svg_fill.png>
>>             Thanks.
>>         _______________________________________________
>>         Qgis-developer mailing list
>>         Qgis-developer at lists.osgeo.org
>>         <mailto:Qgis-developer at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150915/8d596c2d/attachment-0001.html>
