[Qgis-developer] focusInEvent combobox
Luigi Pirelli luipir at gmail.com
Tue Sep 15 10:30:40 PDT 2015
I don't know if I well understood, but can be simply adding a listener
without changing the uic
e.g.
<your GUI instance>.<your combobox
objectName>.focusInEvent.connect(<your QmessageBox function handler>)
regards
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Elance: https://www.elance.com/s/edit/luigipirelli/
* GitHub: https://github.com/luipir
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 15 September 2015 at 11:27, jawensi <jawensi at gmail.com> wrote:
> Hello
> I want to add an event to a combobox. In particular, when the focus change
> to the combobox I want to show a QmessageBox. Shearching the web I find out
> that I can do it reimplementing the focus event handler, but that means
> change the python file generated by the pyuic4 tool. So each time I change
> the ui file I have to add the reimplemented the event. There is another way
> to solve this situation without changing the py file generated from ui file.
> Thank you.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/focusInEvent-combobox-tp5224248.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
