[Qgis-developer] QGIS Server and OL3 GetFeatureInfo requests issue
G. Allegri
giohappy at gmail.com
Thu Sep 17 08:13:26 PDT 2015
Thanks Mathias!
I will investigate it. Maybe an heuristic for the tolerance could be used
on the base of the BBOX coordinates...
giovanni
2015-09-17 15:39 GMT+02:00 Mathias Walker <mwa at sourcepole.ch>:
> Hi Giovanni
> QGIS Server uses a fixed percentage (1 or 2%) of the image size as a
> default tolerance for GetFeatureInfo requests. This works nicely with a
> full sized image e.g. in the QGIS WebClient. But with the smaller image
> size in the OL3 GetFeatureInfo request this results in a single pixel
> tolerance which requires pixel perfect clicks.
> There are new parameters in QGIS Server to set the tolerance in
> GetFeatureInfo requests (should be available from QGIS 2.10):
> FI_POINT_TOLERANCE
> FI_LINE_TOLERANCE
> FI_POLYGON_TOLERANCE
> The tolerances can be set in pixels per geometry type.
> If you add these parameters to your OL3 getGetFeatureInfoUrl() calls, the
> feature info requests should respond to less precise clicks.
> Cheers
> Mathias
> Am Donnerstag, 17. September 2015, 12.07:32 schrieb G. Allegri:
> OL3 has changed the way GetFeatureInfo request parameters are generated.
> The nre way uses fixed WIDTH/HEIGHT and X/Y (I/J) params: 101 for the
> first and 50 latters. Then it builds the BBOX parameter consequently.
> The old way they were built from the size and extent of the map, and the
> query coordinate.
> The new style makes QGIS Server respond with empty results if the click is
> not exactly on the feature coordinates.
> I've tested the same request on the same layer served by Geoserver, which
> responds even with not so precise clicks.
> Can this be caused by coordinates rounding happening inside QGIS Server?
> giovanni
> Giovanni Allegri
> http://about.me/giovanniallegri
> Gis3W - http://gis3w.it
> Ikare - http://ikare.it
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, 8004 Zürich, Switzerland
> Tel: 044 440 77 11 Direkt: 044 515 67 71
> mwa at sourcepole.ch http://www.sourcepole.ch
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150917/778e1a7c/attachment.html>
