[Qgis-developer] Crash on exit
Matthias Kuhn matthias at opengis.ch
Fri Sep 18 06:07:13 PDT 2015
Hi all,
These crashes can have different reasons (e.g. for the plugin at
Andreas' place it's becuase of a custom expression function which seems
to get double deleted). Some of these can probably be prevented by
changes in QGIS core, some will require changes in the plugin.
The best method I can think of is to reproduce the problems on a
computer where QGIS is running in debug mode (or at least capable of
producing a stacktrace) and decide case-by-case.
For the minidump - which would theoretically also include a stacktrace -
I am not sure if anybody is actually capable of analyzing it.
I'm sorry to tell you that I doubt that there's an easy way to deal with
it. Or a generic approach to "catch" this and prevent QGIS from crashing.
Just my 2c, if anybody has an idea to fix it once and for all, please
speak up :-)
Matthias
On 09/18/2015 02:38 PM, Blumentrath, Stefan wrote:
> Related tickets are here:
> http://hub.qgis.org/issues/10823
> http://hub.qgis.org/issues/11891
> https://hub.qgis.org/issues/11901
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Paolo Cavallini
> Sent: 18. september 2015 14:29
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Crash on exit
> Il 18/09/2015 14:25, Andreas Neumann ha scritto:
>> It is not a plugin from the public plugin repository, but a plugin
>> developed by ourself from the waste-water project ;-) apparently it
>> was a known-problem - but I did not know.
> oh, I see, thanks. I'm asking because it happens with several plugins, and I believe we should make something to make QGIS more robust, and intercept these errors before crashing.
> If your plugin crashes QGIS systematically, it could be a good test case.
> All the best, and thanks.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
