[Qgis-developer] QGIS Server crashes and logging
René-Luc Dhont rldhont at gmail.com
Fri Sep 18 07:14:38 PDT 2015
Hi Andreas,
ECW is not causing crash.
You can add QGIS log to have more logs
  FcgidInitialEnv QGIS_LOG_FILE "/var/log/apache2/qgis.log"
  FcgidInitialEnv QGIS_LOG_LEVEL 0
Regards,
René-Luc
Le 18/09/2015 16:12, Andreas Neumann a écrit :
> Hi,
> I am still trying to find out why QGIS server crashes on one of my
> machines (master version).
> If I run qgis_mapserv.fcgi on the command line I get the following output:
> Konsole output
> an at laotop:~/cgi$ ./qgis_mapserv.fcgi
> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
> environment variable.
> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
> Content-Length: 206
> Content-Type: text/xml; charset=utf-8
> <ServiceExceptionReport version="1.3.0"
> xmlns="http://www.opengis.net/ogc">
> <ServiceException code="Service configuration error">Service unknown
> or unsupported</ServiceException>
> </ServiceExceptionReport>
> Could it be that my ECW/JP2 warning are causing the crash (500 http
> error code)? Is this the problem?
> On another matter:
> QGIS_SERVER_LOG_FILE / _LEVEL never worked for me. I specified the
> following in /etc/apache2/mods-enabled/fcgid.conf:
> Konsole output
>  FcgidInitialEnv QGIS_SERVER_LOG_FILE "/var/log/apache2/qgis_server.log"
>  FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
> I created the file /var/log/apache2/qgis_server.log and made sure it
> is writable by everyone - however, it always stays empty. Is level 0
> the most verbose code? Why is it not working?
> Thanks for any ideas,
> Andreas
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150918/a16fd9ce/attachment-0001.html>
