[Qgis-developer] [QGIS-Server] Add a Short Name to layers for OGC	Web Services
    René-Luc Dhont
    rldhont at gmail.com
    Mon Sep 21 02:06:42 PDT 2015
Hi Devs,
Hi Marco,
With some QGIS-Server user feedbacks, we think that it will be usefull
to add an OGC Web Service (WMS, WFS, WCS) Name to metadata layers.
We think that we need to add an input to specify a OGC Web Service Name
because a lot of users use QgsMapLayer.name() as a title.
QgsMapLayer.name() is used by user as a title because it's the label in
the QGIS legend and in the composer legend.
An other point is that currently if the user activates 'Use layer id as
name' in the Project Properties and does not set the title in the layer
metadata, the QgsMapLayer.name() will be used as the OGC Web Service Title.
In the WMS implementation specification, The Name is a text string used
for machine-to-machine communication while the Title is for the benefit
of humans. For example, a dataset might have the descriptive Title
“Maximum Atmospheric Temperature” and be requested using the abbreviated
Name “ATMAX”.
In the WFS, the Name has to be a valid XML Tag name and Tag names cannot
contain any of the characters |!"#$%&'()*+,/;<=>?@[\]^`{|}~|, nor a
space character, and cannot start with |-|, |.|, or a numeric digit.
The QgsMapLayer.id() can be a valid OGC Web Service, but it is too long
and it's not an abbbreviated Name.
I propose to add a Short Name in the layer metadata which will:
* be stored as a WMSName element
* accessible through QgsMapLayer.shortName()
* be used as OGC Web Service Name if it has been set and 'Use layer id
as name' has not been checked
Remarks are wellcome.
René-Luc D'Hont
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150921/b9a638c0/attachment.html>
