[Qgis-developer] Minidump when using GDAL in plugin
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Sep 24 05:10:19 PDT 2015
That is most likely exactly the issue which a couple of other plugins face...
http://hub.qgis.org/issues/11901
http://hub.qgis.org/issues/10823
http://hub.qgis.org/issues/11891
Your report might be a step forward in solving this issues? Do we need a bug report up-streams for GDAL?
Cheers
Stefan
-----Original Message-----
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of jawensi
Sent: 24. september 2015 12:58
To: qgis-developer at lists.osgeo.org
Subject: [Qgis-developer] Minidump when using GDAL in plugin
Hello,
I have problems with DEMto3D
<https://github.com/jawensi/DEMto3D/tree/master/DEMto3D-QGIS> plugin.
Using this plugin in QGIS 2.10.1, QGIS crash on exit. Instead I test it in QGIS 2.8.1 and works fine without minidump message on exit.
I've tracked the problematic code and I find out that it's the use of the GDAL function ReadAsArray, for reading the content of a raster band.
/dem_dataset = gdal.Open(path_layer[0])
band = dem_dataset.GetRasterBand(1)
data = band.ReadAsArray(x_off, y_off, col_size, row_size) /
The plugin works, but the problem is the crash dump on exit.
Any idea if the problem is in the plugin or in QGIS.?
Thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/Minidump-when-using-GDAL-in-plugin-tp5225874.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
