[Qgis-developer] Minidump when using GDAL in plugin
jawensi
jawensi at gmail.com
Thu Sep 24 03:57:54 PDT 2015
Hello,
I have problems with DEMto3D
<https://github.com/jawensi/DEMto3D/tree/master/DEMto3D-QGIS> plugin.
Using this plugin in QGIS 2.10.1, QGIS crash on exit. Instead I test it in
QGIS 2.8.1 and works fine without minidump message on exit.
I've tracked the problematic code and I find out that it's the use of the
GDAL
function ReadAsArray, for reading the content of a raster band.
/dem_dataset = gdal.Open(path_layer[0])
band = dem_dataset.GetRasterBand(1)
data = band.ReadAsArray(x_off, y_off, col_size, row_size) /
The plugin works, but the problem is the crash dump on exit.
Any idea if the problem is in the plugin or in QGIS.?
Thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/Minidump-when-using-GDAL-in-plugin-tp5225874.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
