[Qgis-developer] New authentication system ready
Tim Sutton
tim at kartoza.com
Sat Sep 26 01:33:58 PDT 2015
Hi Larry
Great to see this new feature make its way into QGIS. One thing I am curious about is what happens when we want to publish a project in QGIS server. What is the standard workflow for that or similar situations (e.g. shared project stored on a network drive?
Regards
Tim
> On 25 Sep 2015, at 14:59, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hi devs,
> As you can see in the PR [0], I've fixed up some things, including adding the ability to edit an authentication ID, which will help with workflows where users need to share projects. I've also cleaned up the interface and moved most PKI-related dialogs out of the main Options view.
> I am working on another widget that can be used for the Handle Bad Layers and the Layers Properties dialogs. That should work for most issues occurring when sharing projects and when users open projects with missing authentication IDs. I've also added feedback in the selector widget when it tries to load a config ID that is missing.
> I should have those bits done today, then it's mostly work on finishing the unit test migration to C++.
> **However, I would like to merge this now, since it is in a very good state for doing so. Does anyone have objections with me merging this?**
> [0] https://github.com/qgis/QGIS/pull/2330 <https://github.com/qgis/QGIS/pull/2330>
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> On Wed, Sep 23, 2015 at 4:38 AM, Luca Manganelli <luca76 at gmail.com <mailto:luca76 at gmail.com>> wrote:
> On Tue, Sep 22, 2015 at 10:02 PM, Régis Haubourg
> <regis.haubourg at eau-adour-garonne.fr <mailto:regis.haubourg at eau-adour-garonne.fr>> wrote:
> > Wooooh. that's huge work Larry. Will need quite some time to inspect all that
> > and give some feedback. Any way , bravo!
> > Régis
> +1. The documentation is a MASSIVE job. Compliments!
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/qgis-developer <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
Tim Sutton
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150926/87e6e93a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150926/87e6e93a/attachment-0001.png>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150926/87e6e93a/attachment-0001.pgp>
