[Qgis-developer] QGIS Master crashes on exit
Casper Børgesen (CABO)
CABO at NIRAS.DK
Mon Sep 28 01:04:19 PDT 2015
Hi!
I'm using QGIS master x64 from OSGeo4W, and I'm experiencing crashes (with minidumps) each time I exit QGIS (including if I just open and closes QGIS).
I don't know how to extract a stack trace from the minidump (if it has one?) and renaming the ".qgis2" folder doesn't help.
I have just updated the my MASTER edition from OSGeo4W, based on revision c7a3ea3, but I haven't found a build date for that revision. The "qgis-dev-bin.exe" has a modified date of September 16, 2015, but I would expect it to be newer by now?
I could open a ticket describing the problem, but I'm not sure where the problem is? QGIS code or OSGeo4W builds?
Can any give me a hint?
Regards, Casper
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150928/6e97f0d7/attachment-0001.html>
