[Qgis-developer] QGIS Master crashes on exit
Salvatore Larosa
lrssvtml at gmail.com
Mon Sep 28 01:35:05 PDT 2015
Hi Casper,
On Mon, Sep 28, 2015 at 10:04 AM, Casper Børgesen (CABO) <CABO at niras.dk> wrote:
> Hi!
> I’m using QGIS master x64 from OSGeo4W, and I’m experiencing crashes (with
> minidumps) each time I exit QGIS (including if I just open and closes QGIS).
> I don’t know how to extract a stack trace from the minidump (if it has one?)
> and renaming the “.qgis2” folder doesn’t help.
> I have just updated the my MASTER edition from OSGeo4W, based on revision
> c7a3ea3, but I haven’t found a build date for that revision. The
> “qgis-dev-bin.exe” has a modified date of September 16, 2015, but I would
> expect it to be newer by now?
the date of your revision is a couple of weeks ago (15 Sep), in the
meanwhile a lot of fix have been pushed
Please try a more recent revision, the crash should disappear.
Thanks,
-SL
> I could open a ticket describing the problem, but I’m not sure where the
> problem is? QGIS code or OSGeo4W builds?
> Can any give me a hint?
> Regards, Casper
> Qgis-developer mailing list
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
