[Qgis-developer] Suggestion: Remove Vector | Openstreetmap tool from QGIS 2.12
Anita Graser anitagraser at gmx.at
Mon Sep 28 10:05:59 PDT 2015
Hi Mathieu,
Thanks for your insights! So you are not encountering the issues described
in the ticket? Or are you using it for a very specific purpose which is not
impacted by the issue?
Best wishes,
Anita
On Mon, Sep 28, 2015 at 6:56 PM, Mathieu Pellerin <nirvn.asia at gmail.com>
wrote:
> That'd be a big -1 for me. I use the current OSM tool shipped by default
> on a monthly basis.
> On 28 Sep 2015 22:55, "Anita Graser" <anitagraser at gmx.at> wrote:
>> Hi,
>> I would like to suggest removing the Openstreetmap tool from Vector menu
>> for the upcoming release. Reason: It does not work. The resulting DBs are
>> incomplete.
>> See discussion in
>> http://lists.osgeo.org/pipermail/qgis-user/2014-May/027668.html
>> and related ticket https://hub.qgis.org/issues/8878
>> Also, the workflow is far from intuitive.
>> Currently, the Quick OSM plugin seems to be the much more reliable
>> option. Maybe we could add that to core instead?
>> Best wishes,
>> Anita
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150928/adf460fe/attachment.html>
