[Qgis-developer] Proposal: removing Processing from plugins repo
Victor Olaya
volayaf at gmail.com
Mon Apr 4 03:21:46 PDT 2016
> BTW, another issue: currently a subplugin can be deactivated (and should
> be activated) both from plugin manager and from Processing.
> IMHO the second step should be skipped.
> All the best.
Since the latest UI changes, deactivating a plugin in the Processing
options doesnt mean disabling it, only not showing it in the toolbox,
so it's not the same thing. The algorithms are "active" if the plugin
that contributes those algorithms is enabled (can be run from console
or as part of a model), but they dont show up on the toolbox
