[Qgis-developer] Proposal: removing Processing from plugins repo
Paolo Cavallini cavallini at faunalia.it
Mon Apr 4 20:30:56 PDT 2016
Il 04/04/2016 12:21, Victor Olaya ha scritto:
>> BTW, another issue: currently a subplugin can be deactivated (and should
>> be activated) both from plugin manager and from Processing.
>> IMHO the second step should be skipped.
>> All the best.
> Since the latest UI changes, deactivating a plugin in the Processing
> options doesnt mean disabling it, only not showing it in the toolbox,
> so it's not the same thing. The algorithms are "active" if the plugin
> that contributes those algorithms is enabled (can be run from console
> or as part of a model), but they dont show up on the toolbox
Hi Victor,
thanks for the explanation. However, I'm not sure this is immediately
understandable for the user. I believe if one installs a plugin, he
expects to find it activated straight away. Currently he has sometimes
to activate it in plugin manager and also in Processing providers.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
