[Qgis-developer] Proposal: removing Processing from plugins repo
Victor Olaya
volayaf at gmail.com
Mon Apr 4 22:24:31 PDT 2016
But that's an option in the provider. Some providers should be by
default disabled in Processing (for instance if they require an extra
setup -R- or there is another that is similar -GRASS and GRASS 7-).
For providers that come from a plugin, they should be active by
default, if they want users to have it enabled without going to
Processing and checking the correspodning box. So, in short, that is
an issue of the Provider plugin itself, since you can tell Processing
to have it enabled by default.
Hope this helps
2016-04-05 5:30 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 04/04/2016 12:21, Victor Olaya ha scritto:
>>> BTW, another issue: currently a subplugin can be deactivated (and should
>>> be activated) both from plugin manager and from Processing.
>>> IMHO the second step should be skipped.
>>> All the best.
>> Since the latest UI changes, deactivating a plugin in the Processing
>> options doesnt mean disabling it, only not showing it in the toolbox,
>> so it's not the same thing. The algorithms are "active" if the plugin
>> that contributes those algorithms is enabled (can be run from console
>> or as part of a model), but they dont show up on the toolbox
> Hi Victor,
> thanks for the explanation. However, I'm not sure this is immediately
> understandable for the user. I believe if one installs a plugin, he
> expects to find it activated straight away. Currently he has sometimes
> to activate it in plugin manager and also in Processing providers.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
