[Qgis-developer] Proposal: removing Processing from plugins repo
Paolo Cavallini cavallini at faunalia.it
Mon Apr 4 22:49:05 PDT 2016
Il 05/04/2016 07:24, Victor Olaya ha scritto:
> But that's an option in the provider. Some providers should be by
> default disabled in Processing (for instance if they require an extra
> setup -R- or there is another that is similar -GRASS and GRASS 7-).
> For providers that come from a plugin, they should be active by
> default, if they want users to have it enabled without going to
> Processing and checking the correspodning box. So, in short, that is
> an issue of the Provider plugin itself, since you can tell Processing
> to have it enabled by default.
> Hope this helps
It does indeed, thanks again. Apparently some developers fid it
difficult to grasp, as not all Processing plugins are enabled by
default, nor even these who do not require special setup.
Could you please pont me to an explanation of this, so I can help plugin
writers to fix it?
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
