[Qgis-developer] share plugins (English required)
Martin Landa
landa.martin at gmail.com
Tue Apr 5 12:43:18 PDT 2016
Dear Richard,
2016-04-05 21:37 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net>:
> fyi, I just downloaded your
> http://geo.fsv.cvut.cz/osgeorel/qgis-plugins.xml?qgis=2.15
> put in in my local /var/www/
> added http://localhost/qgis-plugins.xml as a repo named 'test'
> and just installed it flawlessly (having 4 buttons now in my toolbar)...
> I first looked at the metadata of the plugin in the zip, and thought
> that maybe the encoding/diacretic chars could be a problem.
> But then I just tried to install as above and it worked..
sorry, but what means "as above"?
> So: not sure what exactly your issue is.
Is there any way how to determine if the zip file is downloaded, where
it failed. The error message doesn't say anything useful.
> Are you in an proxied environment?
No.
> Do other plugins (from qgis repo) just install?
Yes. Thanks for your feedback, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
