[Qgis-developer] share plugins (English required)
Richard Duivenvoorde
rdmailings at duif.net
Tue Apr 5 12:37:17 PDT 2016
Hi Martin,
fyi, I just downloaded your
http://geo.fsv.cvut.cz/osgeorel/qgis-plugins.xml?qgis=2.15
put in in my local /var/www/
added http://localhost/qgis-plugins.xml as a repo named 'test'
and just installed it flawlessly (having 4 buttons now in my toolbar)...
I first looked at the metadata of the plugin in the zip, and thought
that maybe the encoding/diacretic chars could be a problem.
But then I just tried to install as above and it worked..
So: not sure what exactly your issue is.
Are you in an proxied environment?
Do other plugins (from qgis repo) just install?
Regards,
Richard
On 05-04-16 18:40, Martin Landa wrote:
> Hi,
> 2016-04-01 22:17 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
>> yes, I was thinking about that. I will create local repo for my
>> OSGeoREL at the CTU. No problem with hosting I am working at the
>> university. Plugins (student projects) which will pass requirements
>> for QGIS repo will be moved there after some testing.
> is it possible to provide `download_url` which links directly to
> github, or do I need to create zip file manually?
> Here is example of my repo [1]. Installing the plugin fails:
> Plugin installation failed:Failed to unzip the plugin package.
> Probably it's broken or missing from the repository. You may also want
> to make sure that you have write permission to the plugin directory:
> /home/martin/.qgis2/python/plugins
> Debug messages says:
> src/core/qgsnetworkaccessmanager.cpp: 94: (queryProxy) [147ms] using
> fallback proxy for
> src/core/qgsnetworkaccessmanager.cpp: 94: (queryProxy) [1ms] using
> fallback proxy for
> http://plugins.qgis.org/plugins/plugins.xml?qgis=2.15
> src/app/pluginmanager/qgspluginmanager.cpp: 1031: (setCurrentTab)
> [940ms] Switching current tab to Plugins
> src/core/qgspythonrunner.cpp: 32: (run) [2272ms] Running
> pyplugin_installer.instance().installPlugin('master')
> src/core/qgsnetworkaccessmanager.cpp: 189: (createRequest) [5ms]
> Adding trusted CA certs to request
> fallback proxy for
> https://github.com/ctu-osgeorel-proj/bp-pesek-2016/archive/master.zip
> Thanks, Martin
> [1] http://geo.fsv.cvut.cz/osgeorel/qgis-plugins.xml
