[Qgis-developer] Travis timeouts
Sandro Santilli strk at keybit.net
Thu Apr 7 08:48:48 PDT 2016
On Thu, Apr 07, 2016 at 05:41:00PM +0200, Matthias Kuhn wrote:
> > Use docker to avoid deps builds ? Not sure if/how travis supports
> > this. Pretty sure gitlab-ci does (in case you plan to add a mirror
> > there).
> Docker is supported but not on container based builds
Can't you chose the docker to use as the base, for container based
builds ? What I was suggesting is that you prepare "qgis testing"
dockers to use as base.
--strk;
